1994 johnson lower unit question
johnboy2b
i have a 1994 johnson 150. the lower unit went out and having to replace it. the question i have is will a lower unit off a 90 v-6 fit my 94 it is a 60 degree. i have been told that it will swap i just have to change shafts and shift rod. can anyone help. i have looked thru forum and not found anything to confirm.
jonesg
Re: 1994 johnson lower unit question
You could compare part numbers on evinrude.com
if it don't work, you can always sell it again.
