  #1
Old September 10th, 2009, 06:39 PM
basalt51 basalt51 is online now
Default 1993 SV-19 F-I/O Top Speed?
I just purchased a '93 SV-19 F-I/O with the 4.3L Merc Alpha I. I've only taken it out once and I was able to get up to 31mph GPS at WOT. I don't know if thats all this thing can do since its pretty big or if it should be going faster.
Couple reasons I ask. The linkage seems like it needs adjusting. Drive engages fine at ~10 o'clock, but then there is a lot of resistance to increase the throttle and there is little to no fine control. WOT is easy, but its almost impossible to slowdown just a little. I pull back on the lever and the wife and kid crash into the dash since the throttle goes to idle. Also probably just due to having too much resistance.
Other reason is at WOT, the boat surges a little every 10 seconds or so. I wish I could say what the RPMs were, but the tach appears to get stuck a 3400 so its not very useful.
Thanks
EDIT: I'll try to add prop details when I get home.
  #2
Old September 11th, 2009, 03:22 AM
Default Re: 1993 SV-19 F-I/O Top Speed?
Prop says 19p, and the out drive is 1.84 ratio.
  #3
Old October 5th, 2009, 03:09 PM
Figure I'ld update this since this post. Turns out most of my issues were due to moisture in the distributor cap causing a bad misfire. A full tuneup and its running great.
WOT I was hitting 36 MPH GPS. Tach is still hit and miss so I don't trust its readings at all. It sounded like it was making much better RPMs this go around though.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude 1993 spitfire stalling at low speed smarvelle Johnson & Evinrude Outboards 10 July 8th, 2008 03:06 PM
1993 Force 120 Slipping in Forward Gear@Hi-speed TrophyFish'n Force & Chrysler Outboards 18 June 28th, 2005 08:50 PM
1993 Johnson 48 spl low speed only Camone Johnson & Evinrude Outboards 3 August 13th, 2003 05:54 PM
Idle speed 1993 Evinrude 115 HP Bob Gaunt Johnson & Evinrude Outboards 7 March 31st, 2002 12:44 PM
Idle speed 1993 Evinrude 115 HP Bob Gaunt Johnson & Evinrude Outboards 2 February 13th, 2002 05:47 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
