  #1
Old September 10th, 2009, 01:52 PM
gixxer285 gixxer285 is offline
Default evinrude electric fuel pump
I have an 89 evinrude 150xp. Someone has put an electric fuel pump on it. The hot wire from the pump is run to the purple wire from the rectifier on the terminal block. Boat ran great until i changed the rectifier (old one bad, 35 amp). Now engine boggs trying to come up on plane. Once on plane it runs great. Could the increase of volts to the pump be causing this problem. It is also much harder to start now. Carbs are clean been though twice. Any ideas would be appreciated cause im out of them.
  #2
Old September 10th, 2009, 03:38 PM
jonesg jonesg is offline
Default Re: evinrude electric fuel pump
Spark gap test it at 7/16th inch gap to see if theres a weak ignition on a cyl or two. Let it come up to temp in case of a coil going south at operating temps. Then do the gap test.
If spark is good, blue and strong, then go back to fuel delivery.
__________________
I don't read private messages.
Get the genuine factory service manual.
www.outboardbooks.com
www.marineengines.com
  #3
Old September 10th, 2009, 04:17 PM
Silvertip Silvertip is offline
I sure hope the engine never dies due to a mechanical failure and you forget to turn the key off. A failure such as a stuck float or needle and seat in a carb can fill the engine with fuel. You now hit the starter and -- well -- does the word "kaboom" have any significance for you. Very dangerous practice.
Yes -- modern EFI/DFI engines have electric fuel pumps but they also have the electronics to know when the engine is running and will kill the pump if the engine dies.
  #4
Old September 10th, 2009, 07:09 PM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
Dump the pump !!!! (electric one that is)
Disaster waiting to happen.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #5
Old September 11th, 2009, 09:34 AM
I have tried a spark gap test and it made the 7/16th jump. Also i have replaced powerpak, coil, plugs, and fuel filter. None of those helped mechanic now says its fuel after i replaced all of those electronics and try replacing all the fuel lines. I'm doing that today and since I'm out of ideas I'm going to put the old rectifier back on since the problem started immediately after i changed rectifiers. I appreciate any help i can get.
  #6
Old September 11th, 2009, 09:48 AM
tx1961whaler tx1961whaler is offline
That fuel pump is not supposed to be on there.
If you have good compression and spark on each cylinder, then all that is left is the fuel delivery.
There are proper premix (non-VRO) pumps made for the motor. The "someone" that put the electric pump on was being lazy.
  #7
Old September 11th, 2009, 03:11 PM
I agree pump was on bass boat when i bought it. This is my first boat and if I knew more about boats when i got it I might not have purchased it. But it has run great, I've even pulled tubes.
  #8
Old September 11th, 2009, 03:19 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
those carbs have 3 sets jets in each carb. did you remove all 6 of them. could be ethanol.
right replacement pump a necessity.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #9
Old September 12th, 2009, 05:49 AM
The jets in the carbs are fixed can not be removed and there is no adjustments on the carbs either. I thought about ethanol but that is the only gas i can get around here. After having the boat for a while I have discovered that the rectifier was for a 10 amp motor mine is a 35 amp and someone has put an electric fuel pump on in instead of a VRO so it is very possible that the carbs weren't made for it either.
  #10
Old September 12th, 2009, 07:01 AM
the most certainly can be remove, i have done it many times. they are called fixed because they are not adjustable, not that they can not be removed and cleaned and the ports cleaned. read carb cleaning here. http://forums.iboats.com/showthread.php?t=299680
you can see the complete diagram of your carb here. http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
__________________
FLORIDA GATORS
TEBOW Country
  #11
Old September 12th, 2009, 05:29 PM
Yest. took new 35amp working rectifier off motor and put old 10 amp non working rectifier (one that came on motor when bought) back on. Just returned from lake and with the boat sitting for a month and a half I hit the key one time and it fired up and ran great no problems getting on plane and run strong all the way to top end. Only hiccup was when I tried to power boat back on trailer and it acted like it was flooding out and i could smell fuel real strong but just by changing the rectifier i fixed a planing problem i have been fighting since march. Now what sense does that make I thought rectifiers didn't affect how an engine runs. New rectifier runs at 15-15.2 volts at WOT old one 12.8 could that difference of volts going to the electrical fuel pump be causing the whole problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
electric fuel pump and water separating fuel filter docpaulo Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 March 27th, 2008 11:02 AM
Electric fuel pump for evinrude 235 Jeb1971 Johnson & Evinrude Outboards 10 December 1st, 2007 08:51 PM
Fuel Problem? -- 97, 4.3L GL, 2Bbl Holly, electric fuel pump cpjxh7 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 32 July 17th, 2006 03:16 PM
fuel/water separator with electric fuel pump marlinempress Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 29th, 2005 05:05 AM
electric fuel pump for 1951 25hp evinrude what66 Non-Repair Outboard Discussions 5 July 21st, 2004 12:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
