  #1
Old September 10th, 2009, 11:49 AM
Silent Player Silent Player is offline
Default Aluminum Prop Differences
I'm looking at getting a new aluminum prop. Is there a drastic difference between the $99 prop and the $140 prop? Same diameter, same pitch, etc.
  #2
Old September 11th, 2009, 01:51 AM
hwsiii's Avatar
hwsiii hwsiii is offline
Send a message via Yahoo to hwsiii
Default Re: Aluminum Prop Differences
Which exact props are you talking about.
H
  #3
Old September 11th, 2009, 10:53 AM
The props are all on iboats. I'm looking at the Solas Amita, QL by Volvo Penta, Solas Rubex, and Quicksilver Black Diamond.
I've heard good things about the Hustler Turning Point series, however I can't find any where that sells them for my outdrive (1989 OMC Cobra). Maybe I'm not looking hard enough?
  #4
Old September 11th, 2009, 12:43 PM
hwsiii's Avatar
Quote:
Re: Prop question
Hello HWSiii,
Sorry for the delay in responding. My direction has changed since my last email. I ended up putting smart tabs on my boat (wow, these things are amazing).
I originally thought I would need a 4 blade to get out of the hole quicker and keep a lower on plane speed, but now I think a 3 blade will work fine.
I also put my Viper 14 1/4 X 19 stainless prop on my boat. With this and my smart tabs, I'm definitely over revving the engine at 5100 rpm, at 37 mph.
Do I need to go to a 21 pitch, 3 blade prop? Also, on average (rough guess), how much top speed do you gain from moving 2 degrees pitch?
Thanks for you help and guidance,
Michel
Quote:
Originally Posted by hwsiii
Michel, I think you are on the right track I just need a little more information. Give me the RPM and speed numbers from 2,500 RPM to WOT in increments of 250 RPM.
H
Quote:
Originally Posted by Silent Player
Hello,
I figured I'd send you a private email, since you seem to be the authority on prop questions. Here's the specs on my boat:
1)1990 Chaparral 2050SL
2) LOA: 20' 3", 8' beam, 3,000 lbs.
3) Max hp is 275 hp. I couldn't find recommended
4) Normally 2 adults and 25 gals fuel (47 gal cap)
5) 17 deadrise
6) 1989 OMC Cobra 4.3
7) 160hp with 1.68 ratio
8) Recommended WOT 4200-4800
9) It does have a hydrofoil on there (early model)
10) Current prop: Bombardier aluminum 14 1/4 X 19 3 blade.
11) WOT is 4900 rpm, 39 mph gps with 2 adults and 25 gal fuel.
12) At sea level
13) Tuned up last year: New cap & rotor, plugs and wires, and carb rebuilt this spring. Compression is good on all cylinders.
14) Prop on boat has been on for 2 full seasons. It has a few ding and nicks on the leading edge, and the ends are a little worn. No vibration.
Goal for new prop: Boat currently has good hole shot. I've read your posts, and I think my boat is probably under powered. I'd like to get a 4 blade aluminum to cruise at a lower RPM. However, I feel that I may be able to get a slightly higher WOT speed (the last 300 rpms feel like they are over spinning the prop).
I'm looking at getting a 4 blade aluminum Solas Amita. It's a 14 1/4 X 19.
Just looking for your opinion.
Thanks,
Michel
OK let's take the SS Viper prop you have now and bring it to a prop shop and have them change the theoretical pitch on it by 2", that will bring your RPM down and your speed up.
H
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Holes in Cavitation Plate Gator2614 Boat Topics and Questions (not engine topics) 4 June 4th, 2009 10:53 PM
Holes in cavitation plate - should I repair? gamarines2 Boat Topics and Questions (not engine topics) 2 February 4th, 2009 12:14 AM
filling holes in the cavitation plate fletcher Mercury & Mariner Outboards 3 August 23rd, 2008 10:39 PM
Holes in cavitation plate MountainView Non-Repair Outboard Discussions 7 July 1st, 2007 12:29 AM
filling holes in cavitation plate ryrepsak Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 May 13th, 2005 03:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
