What is the name of this part?
auntb
115 HP Mercury outboard motor. When I trim up the motor, there is a strap underneath. It is frayed on the left side. What do you call this strap? I would like to replace it. What is it's purpose?
:confused:
corm
Re: What is the name of this part?
Hi,
I don't remember what it is called but it stops your motor from ending up in the boat with you if you hit something. You have hit something hard enough to break metal things before that could happen. Like the hydrolic cyl mounting brackets. I have seen one break but not both of them. They break where the 5/8 bolt goes though to mount the top of the trim ram.
