  #1
Old September 10th, 2009, 01:04 AM
WRIGHTWARREN WRIGHTWARREN is offline
Question 150 Mariner Compression Loss 2 Cylinders.
I Have A 150 Mariner.went To Lake,started Right Up,wot And Started To Plane And Then It Started Making A Knocking Sound And Died.started It Back Up And Still Knocking But Got Back To Ramp.got Home And Checked Compression.1 And 2 Cylinder Have No Compression.the Other 4 Have Around 115.what Would Cause These 2 Top Cylinders To Quit At Same Time? I Was Told There May Be A Compression Relief Valve Keeping It From Having Compression But I`m Not Sure.any Ideas Or Help Would Be Great.thanks
  #2
Old September 10th, 2009, 02:51 PM
bully-85 bully-85 is offline
Default Re: 150 Mariner Compression Loss 2 Cylinders.
more than likely you burnt a piston and or broke some rings. inspect the spark plugs for signs or molten aluminum ( dry grayish color). if you have access to a flexible light that you can get into the spark plug hole look toward the center exhaust side and inspect the piston edges for damage.
  #3
Old September 10th, 2009, 04:19 PM
All I See Is A Little Bit Of Carbon.nothing Out Of The Ordinary.is It Normal To Lose Both Top Pistons At Once Like That?
  #4
Old September 10th, 2009, 04:25 PM
j_martin j_martin is offline
Usually a cooling problem will stick the top two pistons like that. If you borescope it you will find aluminum stuck to the cylinder walls.
sorry
John
  #5
Old September 10th, 2009, 11:41 PM
Thanks For The Info.im Going To Pull The Heads And Have A Look.both Pistons Still Move Up And Down When The Engine Turns Over But Im Sure The Walls Are Scored And The Rings Are Shot.thanks
  #6
Old September 11th, 2009, 11:13 PM
yep,just like you said.pistons are shot and walls are scored.i think i will find another outboard rather than fix this one.thanks for the help and info.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
cylinders 5 and 6 low compression Thumbtack Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 February 29th, 2008 05:36 PM
Help Low compression in one of my Cylinders sebas54 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 September 18th, 2007 04:38 PM
67 evinrude 80hp loss of power on #2&4 cylinders jtwags Johnson & Evinrude Outboards 9 September 14th, 2006 10:14 PM
Inconsistent loss of power in 4 of 8 cylinders MelLandry Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 August 7th, 2006 01:22 PM
1988 85hp Loss spark on all cylinders BluejayII Force & Chrysler Outboards 6 July 22nd, 2005 10:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
