disturbedklownz
- Apr 19, 2009
- 7
Ok ive posted this problem before and i was dead set on thinking it was a fuel problem before it gets to the motor.Well after trying to fix this problem, setting motor on fire and causing a few others problems im back to square one.
Motor 1986 Mercury 115hp I6
Problem!!
Motor bogs downto die sometimes throttling up past 1/4 throttle.It sounds like its flooding itself or starving for fuel.Motor starts fine, idles fine and only does this sometimes (ussually after getting to a fishing spot and sitting for alittle while then powering it back up to move)
Things ive did with no improvement at all.
1.Rebuilt fuel pump twice
2.new fuel lines everywhere from motor back(needed them anyways)
3.Hooked up another tank and bypassed everything on boat besides primer bulb.
4.Changed plugs and fuel filter on motor.
5.Run full can of seafoam through gas.
6.Sprayed seafoam into carbs and let sit overnight.
Somthing i noticed today that its doing but i dont know if its normal.When i squeeze the primer bulb a few times a stream of fuel will squirt out the top carb?!?!?!
ANy help where to go from here would be greatly appreciated.I cant afford to take the carbs to get rebuilt but i think thats my next/only move and i really dont wanna spend money on it becasue i know ill get raped at the local dealers around here.
Problem!!
