Re: Is my water pump bad?
If you don't know when our impeller and fuel pump diaphram were changed last, the prudent thing is to change them. The same goes for the lower oil.
If you are handy, all these jobs are easy. The fuel pump takes about an hour, the oil takes 15 minutes and the impeller will take about two hours. The cost of the diaphram on ebay is $18 with gaskets, the impeller is about $20 or so.
There is a thread in the FAQ at the beginning of the maintenance forums called Waking up a sleeping engine. It is required reading for all new guys.
Just ask for what you don't know, that's what we're here for.
