Whats goin on? So just got my boat back after it bein in the shop for almost two months for not going into to gear. now it wont run over 3800 rpm and it stutters and backfires and if you try to give more throttle will stop running. just had carb rebuilt,new plugs,wires,lower unit service,new fuel pump,timing set and more......got any ideas on what it could be? I was told it could be the E.S.A? but i dont know much about those. The really weird thing is it will act crazy by backfiring sputtering and then just clear up and run smooth until you touch the throttle...all the while only goin 10mph also any ideas on what size prop is supposed to be on there..it has a 13x19 now....thanks
