  #1
Old September 8th, 2009, 09:51 PM
pinballdan pinballdan is offline
Default Mariner 1989 115 hp accelerator pump
I was wondering if the engine should change rpm when you depress the accelerator pump when the engine is Idling ? Every once and a while I go to get on plane and the engine just bogs,you let off and hit it again and the same . Shut it off tilt engine check for weeds and none found and than it will be fine and may not act up for days . I changed the fuel lines and cleaned the injectors and replaced the fuel filter to them and all other lines . but if you push the pump it doesn't change engine speed .should it ?
Dan
  #2
Old September 9th, 2009, 12:24 PM
MercGuy MercGuy is offline
Default Re: Mariner 1989 115 hp accelerator pump
Dan,
If I understand your question, the answer is yes.
I have tested my accelerator pump on a lake by removing the engine cover, starting the engine and letting it idle. Then I took a screwdriver and pushed the plunger on the accel pump and the engine speed blipped up and cylinders 3 & 4 lit. That convinced me that my pump was OK.
HTH
-Steve
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Accelerator Pump?? Shields Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 15 July 3rd, 2009 01:45 AM
Accelerator pump Frank Acampora Mercury & Mariner Outboards 0 June 28th, 2009 12:27 PM
Accelerator pump? TheMoGr Mercury & Mariner Outboards 3 May 25th, 2009 11:08 AM
accelerator pump local933 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 28th, 2008 06:47 PM
Accelerator pump Flyin1500 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 9th, 2007 12:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
