AEROCOOK
Master Chief Petty Officer
- Jul 28, 2004
- 872
In my quest for more speed I have raised my motor up one hole setting on the transom but now the boat porpoises unless it is trimmed all the way in and I put additional weight in the bow.
Here are the details on the boat...
1987 16.5' aluminum bowrider with a 1988 110hp Johnson.
Heres the deal, I also removed the aftermarket cavitation plate fins at the same time so Im not sure which change contributed most to the excessive porpoising that the boat now has.
Idealy I do not want to put the fins back on as they made steering more difficult and when I took them off I welded the holes back up.
So my primary question is whether or not simply raising the motor on the transom could cause the condition?
