Need a meeting site
POINTER94
Had a meeting with my boss and we decided we needed to have a regional meeting. I suggested that we rent a houseboat for the meeting. (sly little bestard ain't I) With all great ideas comes the responsibility, its my job to find a place in 30 days.<br /><br />Requirements include, a warm climate in the Northeast, proximity to an airport of reasonable size, and a really big houseboat..<br /><br />Any ideas????
Skiuseme
Re: Need a meeting site
How about here in La Crosse..... Wait its not warm.
SS MAYFLOAT
Houseboat + Airport = Aircraft carrier! :D Now that would be impressive! Sorry Pointer, can't help you much more than that......SS
LubeDude
:D :D Ha, Ha, Ha, thats a knee slapper for sure, a houseboat excursion in WI. in 30 days. :D :D
sangerwaker
Pointer, have you done any searching on the net?<br /><br />Found this one for ya in Lansing, MI on the Mississippi<br /> ssboatrentals dot com/home.html<br /><br />Here's one on the Ohio in Kentucky<br />waterwayadventures.com/default.aspx<br /><br />Here's a page with one out of LaCrosse and one out of St Charles, MN<br />greatriver.com/GRCruises.htm<br /><br />Good luck!
Define "Northeast".....
JRJ
Lake Shasta has houseboats for rent and it should be warm in 30 days :D shastalake.com
POINTER94
Maine south Virginia west to the Mississippi, and all points north. Give or take 200 miles.
Are you looking to be On the Water in 30 days,.... Or just have it Booked,.??....<br /><br />Warm in 30 days cuts your search area in Half.........<br /><br />Up here on the St Lawrence in Alexandria Bay or Clayton Ny. there are several Marinas renting Houseboats,.....<br />Lots of harbors,+ anchorages.... Kingston Ont. is just on the other side of the Islands......<br />Syracuse has a reginal Airport,... It's an Hour or so.......<br /><br />In Clayton,... French Bay Marina,.... Owned,+ Run by a fella named Kellog,.. I forget his 1st name,...Jerermy I think...<br />He rents quite a few Houseboats,..... 30, 40+'ers......Nice Ships.....<br />He's also a friend of friends.........
SS MAYFLOAT
Pointer, Cumberland Lake in Kentucky is a big lake with very many and huge houseboats for rent. SBN may know more about it. The weather there should be great by then if not now. Good luck.
POINTER94
Thanks guys,<br /><br />Yep I need to have the meeting within 30 days. It is going to be 83 degrees in Wisconsin today. I think that the Ohio, Kentucky area would be best. I found several different locations within this area. I found one place with an 82 footer wich is probably what it will take to keep us from killing each other after just a few days.<br /><br />I will have to get a preliminary OK from the big man so I don't waste my time, but I will keep you all updated as to what I decide. <br /><br />pointer
Speedwagon
Originally posted by sangerwaker:<br /> Pointer, have you done any searching on the net?<br /><br />Found this one for ya in Lansing, MI on the Mississippi<br /> ssboatrentals dot com/home.html<br /><br />
Um, what? Since when does the mighty Miss run into Michigan?
sangerwaker
OOps. That's Lansing, IA.<br /><br />Michigan can't suck hard enough to get the Mississippi over that far. :p :D
