Dirty Carb on mariner 8 hp...
ObeliscO
Hello, I am speaking in Spanish in this post but do not master English very well and in a less technical language, But I write down on the carburetor in spanish language because the next text here is a google english traduction of the my post originally in spanish.
I'm glad I found a forum like this one here that can explain my problem and ask for some advice to solve it ...
A couple of days ago I went fishing with a friend, I am 1.5 miles away and then when I come back, I tried starting the engine is started and when stopped suddenly. After trying unsuccessfully to start it several times to remove the spark plug and check its status was fine. Then I found a blue button next to the carburetor and I pressed it several times and tried to start it and tore ... We returned to the beach and once there we did several tests to check what was wrong the engine. The result is that since then, need to start to press the blue button is in the carburetor a few times, then when it starts, it becomes idle at a stop after a few seconds. In the event that will accelerate and navigate and walk perfectly fine, but to curb and leave it idle again stop.
What I think happens is that the gum is low but I'm not dirty and I need to know whether and how leads 2 gum disassembly and reassembly of the carburetor without any parts let me back ...
If any of you miss me a hand thank you very much.
Best regards and see you soon.
Hola, siento hablar en espa?ol en este post pero no domino muy bien el ingl?s y menos en un lenguaje t?cnico.
Estoy contento de haber encontrado un foro como este por que aqu? puedo exponer mi problema y pedir alg?n consejo para solucionarlo...
Hace un par de d?as sal? a pescar con un amigo, me alej? 1,5 millas y luego cuando quisimos volver, intent? arrancar el motor, y cuando arranc? se par? de golpe. Despu?s de intentar arrancarlo varias veces sin ?xito desmont? la buj?a para comprobar su estado y estaba perfectamente. Luego encontr? un botoncito azul al lado del carburador y lo presion? varias veces y prob? a arrancarlo y arranc?... Volvimos a la playa y una vez all? hicimos varias pruebas para comprobar qu? le pasaba al motor. El resultado es que desde entonces, para arrancar necesita que presione el bot?n azul que hay en el carburador varias veces, luego cuando arranca, estando en ralent? se vuelve a parar despu?s de unos segundos. En el caso de que acelere y navegue va perfectamente y anda muy bien, pero al frenar y dejarlo a ralent? se vuelve a parar.
Lo que yo creo que le pasa es que el chicl? de bajas est? sucio pero no estoy seguro y necesito saber si lleva 2 chicl?s y c?mo desmontar y volver a montar el carburador sin que me deje alguna pieza atr?s...
Si alguno de vosotros me echa una mano lo agradecer? much?simo.
Un saludo y hasta pronto.
rosser1
Re: Dirty Carb on mariner 8 hp...
i don't speak any spanish, but would say to remove carbs, clean them, reassemble them put carbs back on and try to engine then. i bet a good cleaning will work.
ObeliscO
Hi. Thank you for your answer...
I cleaned it and i just ensamble it, and now only try it left...
__________________________
Ya lo he desmontado y limpiado, ahora solo queda probarlo. Gracias
