  #1
Old September 8th, 2009, 12:43 PM
bobthebuilder52 bobthebuilder52 is offline
Default Evinrude 9.9 Fuel Pump problem
My 1991 Evinrude 9.9 would die unless pumping the bulb almost constantly. I put in a NAPA fuel pump rebuild kit (hopefully correctly) and it helped some, but I still have to pump the ball occasionally. I'll have to admit I didn't take adequate notes when I dissassembled the fuel pump for the first time. Also, recently switched to a synthetic blend 2-cycle oil. Motor starts and runs strong otherwise. Thoughts?
  #2
Old September 8th, 2009, 02:30 PM
MAW31 MAW31 is offline
Default Re: Evinrude 9.9 Fuel Pump problem
how do you define 'occasionally'. before you start the motor for the day?
do you have an in-line filter thats clogged possibly?
  #3
Old September 8th, 2009, 02:34 PM
Rick. Rick. is offline
http://www.sschapterpsa.com/rambling...OMC%20info.htm
Good step by step on the pump here. Make certain your tank screen is clear and your pump screen too. Best of luck. Rick.
  #4
Old September 8th, 2009, 11:04 PM
Thanks Rick. Occasionally as in every 20 seconds instead of every 3 seconds. Checked the pump screen and pickup screen already. Rebuilt the pump according to the linked website you sent.
  #5
Old September 9th, 2009, 01:31 AM
So did the rebuild fix the problem? Rick.
  #6
Old September 9th, 2009, 04:12 PM
No, all recent problems after rebuild. Took it out today. Hard to start now, have to pump ball every couple of minutes at no-wake speed. Runs fine at high speed.
Could my switch to a partially synthetic two cycle oil be causing problems. Sometimes the ball pumps up hard, and sometimes it doesn't. It pumped up hard when I went to start it, but had to pull a lot to get it started.
  #7
Old September 9th, 2009, 06:36 PM
Partial synthetic is good and should be no problem as long as your mix is 50:1.
Have you adjusted your slow speed needle and done a link and sinc.? What do your plugs look like? fouled , dry, wet? Rick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 Evinrude 50hp fuel problem- VRO pump?? duponts Johnson & Evinrude Outboards 9 June 23rd, 2005 09:45 AM
1986 Evinrude fuel Pump Problem! friscobasser Johnson & Evinrude Outboards 8 January 28th, 2004 03:39 PM
fuel pump problem for 1972 evinrude 85 hp pillatzki Johnson & Evinrude Outboards 2 August 7th, 2003 04:37 AM
4.5hp Evinrude fuel pump problem..? fishguy Johnson & Evinrude Outboards 5 August 4th, 2003 07:44 PM
Stumped -- Fuel Pump Problem, 25 HP Merc w/integral pump katoom Mercury & Mariner Outboards 7 February 2nd, 2003 04:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
