Re: Unexpected vapor
Exaust manifolds leaked back into the cylinders, hydro lock. (salt water) Cranked to force water out plug holes as best I could. Did not try to start the engine for a couple months, sprayed oil in spark plug holes and would turn it over every once in a while. Drained oil and changed filter. Installed new manifolds and risers. Fired up the engine and heard loud tapping. Stopped, pulled valve covers and noticed the bent rods. Pulled heads. Tapped out 3 stuck valves. Sanded, lubed and lapped valves and established shiney seats. Nothing bent, no pitting and all move easily. Some cylinder walls had minor rust marks, no pitting. Wiped them out and sanded lightly with black wet paper.
Checked compression today. It's all over the place from 40 to 180, but sounds like it runs and idles ok. Checked valve lash again. Seems right.
Can you walk me through the leakdown process? Any other thoughts?
