Hi, been working on a 70 hp chrysler outboard 3 cylinder ( not sure on year). had it running last week, took out to lake and ran for about 15 minutes. the quit. Checked plugs and spark ok, checked all wiring and appears fine, Removed bowls from carbs and found that floats are ok,no fuel from bowls going through the carbs and into cylinders,
wondering if something could be plugged from fuel gumming? doesn't seem to draw the fuel into carb when cranking to start,was going to try misting fuel in with spray bottle any other suggestions?Thanks
