natemoore
Master Chief Petty Officer
- Jun 13, 2009
- 844
I removed the cylinder head from my '87 MCM-165 in order to troubleshoot a vanishing coolant/steam at start-up problem.
When I removed the cast iron coolant tank, I saw coolant down in the #3 and #4 areas of the exhaust manifold. That confirmed my suspicions.
When I started cleaning up the cylinder head, I encountered a lot of rust around the #4 exhaust port, which I'm sure is common. By the time I chipped away the layers of rust, it became evident that the exhaust port wall will be pretty thin and the gasket mating surface in need of resurfacing (if possible).
So, I started looking for rebuilt heads, but I need the casting stamp in order to get the correct one, but guess what. The letters on my casting stamp are totally rusted away.
Here are my questions:
How thin can the #4 exhaust port wall be before I'm risking doing this all over again really soon?
Do machine shops normally resurface the exhaust and intake mating surfaces?
How can I figure out what casting run I have since I can't read the numbers on the outside?
I've got some pictures. I get a link on here ASAP.
Thanks,
Nate
Thanks,
Nate
