I have a 60hp Mercury outboard recently the voltage pegged to 18v on the gauge and stays there on just about anything above and beyond 2k rpms. I took a reading from the battery with a digital multimeter it was at 14.4 volts with the engine at about 3k rpms.
The gauge does drop to 0 when off and rises to about 12-13 when in the run position. Also rises a bit at idle 13-14v.
Should I assume Is the guage faulty or should I test it further? If so give me a hint on where to measure from, this my first Mercury. I was thinking right at the gauge.
