Re: engine wont start when launced in water
helo, this is my first post so here it goes! i have recently bought a 40hp blueband engine it runs great when in a barrel of water at home starts first time and every time i bring it out to the water it will not go! it has to be scared of water or something? it seems to sit very low in the water and i was told when starting it in the water it might suck water through the exhaust if its to low in the water? any ideas? starts first pull when out of the water at home.
A little confusing - you said you run it in the barrel at home then the last sentance, you said "out of the water at home". I'll assume you always start it in a barrel at home.
Sometimes engines that run on a hose at home have problems starting in the water because they can't handle the back pressure on the exhaust. In your case, my guess would be that at the water, the engine is deeper than in the barrel at home. This could cause higher back pressure (because of the depth of the water). Next time try putting the engine in the water just enough to cover the water intake, no more.
I once had a big engine that was very particular about that. If I backed it in to far it was a bear to start. If I paid attention and didn't go too deep, it started fine.
