My Force won't keep it's prime. I need to inject fuel directly into the cylinders to get it started. Once it's started it idles okay(I have other issues I'm working through but that's another story), but when I try to start it after a day or so, I need to re-inject the cylinders with fuel. I put in new plugs and checked the fuel pump diaphragm and it is intact. I am going to be removing the carbs and cleaning them as well as checking the reed valves and the check valves in the fuel pump. Has anyone ever had a Force that won't hold it's prime? Any other tips you could give me? Thanks.
