  #1
Old September 6th, 2009, 12:15 AM
eppsboat eppsboat is offline
Default Larson 180 SEI 2003 Leaking
I just purchased a used 2003 Larson 180 SEI this week and had it on the water for the first time this weekend. To my surprise the boat took on water and even had water in the compartment for ski storage. The bildge pump was able to keep the water level from increasing too much but we still pulled the boat out of the water and plan to take it to the shop next week. Any thoughts on what the problem could be? I purchased the boat from a family that did not used the boat in years and have no thoughts on the cause. Any thoughts beyond doing a much better inspection before purchasing a used boat? thanks
  #2
Old September 8th, 2009, 02:10 PM
rokrau rokrau is offline
Default Re: Larson 180 SEI 2003 Leaking
Hello, first the obvious - you put in the plug, right?
I have a 180 SEI 2001. It takes on a little water that shows in the ski compartment (under the floor). Usually not even during use but after I pull out. There is a hole in the back of the compartment where water can run into the bilge. If the bilge is full of water and you take out the boat the water runs forward when you stop.
I was out all last weekend, on the first day I did not run the bilge pump and there was lots of water when I pulled the plug. On the second day I ran the bilge and there was hardly any water when I took the boat out.
I am in a very similar situation, the original owner whom I trust to tell the truth, did not use the boat in 2 years. So my guess is that the outdrive sealing dries up and becomes brittle and lets water in. It'll be expensive to repair unless you can pull the drive yourself.
I am very interested what you learn, so please keep us posted!
Best
Roland
__________________
Mast- und Schotbruch und stets eine Handbreit Wasser unterm Kiel!
  #3
Old September 8th, 2009, 09:22 PM
soreloser soreloser is offline
I own a 1996 174 SEI, bought recently, same story. The boat wasn't in the water much over the past 3 years. I filled the bilge area and tipped the trailer up and noticed some small beads of water leaving where the drive meets the transom. It is now in the shop, motor and drive pulled. I was shown the seal by the mechanic and it was quite dry/squashed/cracked and he was sure that was the problem. It should be out of the shop tomorrow, will let you know. I am expecting a large bill, about 10hrs labor plus parts. Did the gimbal bearing at the same time as it was all tore down.
  #4
Old September 9th, 2009, 10:23 PM
Thank you both for your replies, I have a feeling I am going to be using these forums a lot as I get started with the boating. Before taking the boat into the shop I decided to do a little exploring myself. I found that the hose used for flushing the engine was not capped. I put on the motor muffs and confirmed that not having the cap on the flush hose caused water to flow directly into the bildge area from the hose. So, I put the cap back on and hope that this solves the entire problem. I will take the boat back out this weekend for a test. I will let you know how it goes. Thanks again for your suggestions.
  #5
Old September 10th, 2009, 11:49 PM
Well, 9hrs labour and a $20 seal. All fixed, just over $1K.
  #6
Old November 6th, 2009, 12:03 AM
fossill fossill is offline
Like they say, "If you want to play, you got to pay"
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
8HP Merc (2003) leaking oil from prop shaft foggysail Mercury & Mariner Outboards 6 October 3rd, 2009 04:41 PM
2003 Larson LXI Dash Board Issues robertwwood Electrics, Electronics and Trolling Motors 2 March 31st, 2009 05:49 PM
outbord leaking gas then not leaking gas mcgill Prop Questions and Topics 5 November 17th, 2008 04:09 PM
2003 Johnson leaking gear oil FormerHR Johnson & Evinrude Outboards 4 March 14th, 2007 05:10 PM
2003 90HP YAMAHA LEAKING OIL FROM OIL RESEVOIR wily Yamaha & Suzuki Outboards 5 September 11th, 2004 08:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
