  #1
Old September 5th, 2009, 10:44 PM
bob30p bob30p is offline
Default Evinrude 70hp 4-stroke Enough Motor?
I'm looking at a 20' Lund Alaskan with a model year 2000 Evinrude 70hp 4-stroke. It seems underpowered considering it's rated for 125hp (I assume that is a 2-stroke capacity). Of course the owner claims it's all I'll ever need, and I guess it could be. The boat itself only weighs about 1200lbs dry and at the very most I might one day want four fisherman and gear in the boat, maybee 800 more lbs? Is anyone running a similar setup? Can anyone comment on the motor itself? My last Lund, a 16' Rebel was underpowered and I don't want to do that again. Thanks
  #2
Old September 5th, 2009, 11:05 PM
Silvertip Silvertip is offline
Default Re: Evinrude 70hp 4-stroke Enough Motor?
Any boat, for reasonable performance should be powered by an engine that is rated no less than 70 - 75% of its maximum rated HP. Since this boat is rated for a 125, a 70 is 56% of the maximum. I suspect this boat is a pig and adding another 800 pounds would make it even more of a pig. 75% of 125 is 93 so that boat should have at least a 90 on it. Capacity does not differentiate between two and four stroke.
  #3
Old September 5th, 2009, 11:26 PM
I brought up the 2-stroke capacity because I figured a 70hp 4-stroke probably weighs as much as a 125hp 2-stroke. Does the max rating have anything to do with the weight of the motor or is it strictly horsepower? In my case, would it make any difference if the motor hanging off the back was a 125hp 2-stroke or a 125hp 4-stroke, even thought the four weighs a lot more?
  #4
Old September 6th, 2009, 12:03 AM
JB's Avatar
JB JB is offline
I agree with Silvertip. I think you need at least 100HP for satisfactory performance from the big Lund.
Several companies offer 115HP 4 strokes that weigh slightly over 400#, about 100# more than a typical 90 or 115 2 stroke. On that boat and "extra" 100# on the transom isn't going to be a problem.
Before you get too stuck on a 4 stroke 115, take a look at the ETEC.
Your EvinZuki DF70 is a very popular engine for lighter, smaller boats.
__________________
RED SKY at night. . .
JB
  #5
Old September 6th, 2009, 08:50 AM
tmfd's Avatar
tmfd tmfd is offline
Send a message via MSN to tmfd
I'm pretty sure I looked at that boat. (motor is painted same color as boat) And ended up buying a different one from the same dealer. I too wondered about the size of the engine. Just out of curiosity, what does the dealer say about the size and how it will push the boat.
__________________
Northern Michigan: Paradise on earth (5 months out of the year)
'88 Starcraft SFM-16
Johnson 60
  #6
Old September 6th, 2009, 12:13 PM
CAUTION: The dealer will tell you anything you want to hear. Do your research and do it well. You only get one chance at this. Look at test reports. Every engine manufacturer has these on-line these days. If you can't find the exact boat, pick one that is similiar in size and weight. If you find the boat but not the engine, go to another engine manufacturers site, and pick the desired HP. The information is available. Use it.
  #7
Old September 6th, 2009, 03:43 PM
26aftcab454 26aftcab454 is offline
I have a 1957 aluminum 18ft LoneStar El Dorado that weighs 780lbs. dry . I have a 1994 Evinrude 115hp (the old school 90 degree block) mounted on a factory 20 inch long transom bracket . The boat has a incredible hole shot and tops out 41MPH WOT. The hull was not designed for that much power in 1957 and I usually don't run over 4,000RPM. it runs about 33MPH there and rides swell.
If I was looking to purchase a new simular rig I would go 115HP Evinrude E-tec. I hope you find the right rig-good luck.
just my $0.02
Joe
__________________
26ftWellcraft 454bravo3
1957LoneStar ElDorado
Living the Dream
  #8
Old September 6th, 2009, 04:15 PM
tmfd,
Yep, that is the boat. Engine cover painted to match. Out of curiosity, when did you look at the boat? What did you think? How much was he asking then? Of course the guy I talked to claimed it was plenty of motor, and like I said, I won't be hauling supplies in the Alaskan wilderness, just 3-4 fisherman at the most. Ideally, I'd like to take it for a ride with at least three guys in it. Do you know if that is an option at this place since you've been there? I haven't actually been there yet. Still trying to figure out if it is worth the drive. Thanks
  #9
Old September 13th, 2009, 01:48 PM
tmfd's Avatar
Sorry I didnt get back with you, I've been up north for 10 days, and sort of forgot about my post. As I said, I did buy my current boat from that dealer. He seemed about like the average dealer, tells you just what you want to hear. But he did replace the one thing I found out wrong, interior side panel was damaged and I removed it and brought it back to him. He cut me out a new one without any holes in it, as I wanted to drill new ones. I'm very happy with the boat so far, but that I consider good luck. I do think he will let you take it out on Gun lake if you want to.
I was very pleased with the performance of my 16ft aluminum hull with just the 60hp, didnt think it would be as good as it turned out to be. See my post here
__________________
Johnson 60
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 70HP Evinrude 4 stroke running rough HELP!! powerfishman Johnson & Evinrude Outboards 1 August 18th, 2009 05:16 PM
Changing impeller on 2000 70hp 4 stroke Evinrude cwebb1112 Johnson & Evinrude Outboards 0 June 12th, 2008 06:57 PM
evinrude 70hp 4 stroke cooling system bob keen Johnson & Evinrude Outboards 4 May 26th, 2008 09:51 AM
1989 Evinrude 60-70hp same bore and stroke ? Graybill Johnson & Evinrude Outboards 1 August 20th, 2003 05:48 PM
What can you tell me about 2001 Evinrude 70hp ERP 4-stroke EFI troyo Johnson & Evinrude Outboards 5 November 22nd, 2002 03:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
