3.0 Engine revs in reverse and eventually catches. This just started yesterday
pontooner
I have a 1998 pontoon with a 3.0 L and a Alpha 1 outdrive. I have had the boat for 3 years and other than a couple of hard to replace starters, it has been a great boat. :)
Yesterday the boat started having problems shifting into reverse. The shifter seems to be working fine, but the boat stays in nuetral when shifted. After I rev the engine a couple of times, it eventually jumps into reverse (Hard). :confused:
I did not receive the motor manual with this used boat. Would this just be a cable adjustment? :confused:
Any advise would be greatly appreciated :)
Thanks guys
Re: 3.0 Engine revs in reverse and eventually catches. This just started yesterday
Ayuh,... Adjusting it Might get you another lap,...
But,...
It's no doubt the begining of the End for the lower shift Cable....
