Re: Beginner needs input.
I just bought an 86 4winns, while the boat is in good shape. Check every wire and clean all the ends with a wire brush and tighten them down, do a compression check, check the seal for the sending unit (assuming its a built in gas tank) if its not perfect just replace it now, check the carb and have it tuned as needed, check the floor for soft spots, check the stingers to see if they are rotted, check the transom for any sines of imperfections in the coatings and do a core sample if you can (wood only), replace the spark plugs and wires, nee battery, and get spare parts.
If I have missed anything please add to it!
I am a new boater to and I am no expert at this, I gathered a LOT of info from this forum and thank everyone that has shared their knowledge, but these are some things I have ran into my self. I spent 3 days cleaning and going over every little thing that could leave me stranded on the water. After I went through it all and found some things that I should have looked at before I bought it, I feel better about being out on the water with it.
I hope this helps!
