rudderless
- Aug 6, 2009
- 4
I have a fresh rebilt merc 470 with a new carb and pertronix ignition sys I have statically timed the eng for 10 deg ( 8 called for ) crab is set at 1 1/4 mixture it has an electric choke set at 5/16 the eng runs but I can not get the idle down past 12/1300 rpm in order to fine tune without it stalling out gas is fresh plugs/wires,coil new. yes there is a resistor wire eng runs ok above 1500rpm smooth but not below could this issue be caused by the electronic ignition sys does anyone have a wiring diagram for this sys any help would be great cheers
