Alpha 1 Lower unit Help
BigBK
Could anyone tell me or let me know where i can learn how to get the cross pin spring and the cross pin out of the sliding clutch?
I can not figure it out, Bob
jtybt
Re: Alpha 1 Lower unit Help
It's a floating pin that slides out if you push the spring to the side.
BigBK
Is the spring located at the bottom of the clutch? the reason i ask is because i can not feel it.
Im trying to get the prop shaft out and i think i have to get these items off first. I need to replace the vertical drive shaft in the lower unit it sheared in two.
BigBK
Well Dumb A.. here really messed up. like i mentioned i sheared the vert drive shaft on a brand new out drive.
After looking and reading the manual you have to put the lower unit into forward to be able to turn the prop shaft and remove the pinon nut. Its kinda hard to do after removing the shift rod. I think this new lower unit is headed to the scrap pile. It only has 12-14 hrs on it. Way to go me!!!!!!!!
BigBK
Well i got it out dispite myself. Could anyone explain how this happens, I have no clue
Bt Doctur
2 reasons i can think of, a missing tooth got jammed in there or a severe prop strike within 2-3 years
BigBK
I looked real closely to all parts no dings, dents, worn or missing teeth.
the drive has never hit a thing, no sand bar, no rocks and no logs
Also it was a new outdrive with less than 15 hrs on it.
Thats why i dont have a clue.
jtybt
I don't see how you got the prop shaft out. A little wiggling and waggling?
The shaft looks like an extremely clean break...as in factory defect. I bet you can get a new drive because of it.
