Mariner 20hp stalls after 4 mins.-no fuel
i have a Mariner 20hp 2-cycle, that will start with no issues, run for about 4 minutes then stall (due to lack of fuel) - after it stalls, you can pump more fuel and it starts - so far i have rebuilt and adjusted the carb, including new fuel and primer pumps (2x's - once by an auto mechanic), replaced the hose and tank with a known "working" setup from another engine - no leaks have been found - any ideas what i can look at next? - the mechanic said i need a new carb. - any help would be appreciated....
