coolguy147
- Jul 14, 2008
- 2,817
ok so i ran the motor for like 2 hours not i got the gas mix at pretty rich with oil like about quart of oil to like 3 gallon of gas i did cause it hasnt ran in a while and i had a little shaving from helicoil go in the 3 cylinder so another reason all good. umm about gallon or less of old gas. now would some old gas and oil make it so it wouldnt idle
i have the low speed needle at 1 turn out both of them i tried 1 1/2 for both it would let me put the warm up lever all the way down and it would idle but its 2 high now i think i got to idle it when the top was 1 out and bottom 1 1/2 and it didnt idle but its not even. also
i could only start when warm when using the choke? whats wrong?
and i found the tele tale kinda but its like drips water and like barely comes out plus when i reved it up and kinda kept it high it would come out ok stream but like onyl did once its not even stream. then exhuast relief is kinda the same.
problem with cooling system? the motor didnt overhear or anything i checked it the whole time so its cooling and strangely for a little bit the third cylinder was hotter then the rest then evened out later
