Re: Whats the smallest boat you had/seen a wakeboard pylon or tower on?
I started family boarding with a 15' 1985 Bayliner with a 50hp Force motor to pull 120 lb kids. I moved to a larger boat but here is how I made this work on the 15..
I built a collapsable tripod in the front bolted to the inside bolts of the bow eye and the other legs resting against the bulkhead in front of the windshield. THis MUST be secured down! I Used handly iron I had from electical projects.
THe 50 HP did NOT have enough to pop them out of the water but remember I am now pulling from the bow not the stern. WHen I would hit power the boat, of course, would squat down in the stern at which moment I, the helmsman, would step HARD in the bow. This would force, the now raise bow, to drop effectively popping them out of the water. It was the dropping of the bow that popped them not the HP. Once popped the 50 towed them fine.
A bit funky but it worked.
