  #1
Old September 3rd, 2009, 03:28 AM
BoatDr BoatDr is offline
Default 1979 Evinrude 115 LEAK?
Well, took my recently overhauled starcraft for its maiden voyage over the weekend and fished a salmon tournament. Here's what the engine looked like after I pulled her out:
Anyone know what could be leaking? She seemed to be running a little rich and stalled a few times on the water while trolling. Could it be a result of running the engine too slow for too long? Any help is appreciated. Thanks.
-Erik
  #2
Old September 3rd, 2009, 06:43 AM
emdsapmgr emdsapmgr is offline
Default Re: 1979 Evinrude 115 LEAK?
Looks like the powerhead base gasket has failed. While not a fatal problem, it is messy. Usually when that gasket fails, it will also leak exhaust gas/smoke into the cowling. This smoke will get re-ingested into the airbox and get sucked back into the engine. You may see some running issues as it gets worse. Time to pull the powerhead and replace the gasket. Some base gaskets are just paper, and others have a pc of metal sandwiched between the paper sides. The plain paper ones are no good.
  #3
Old September 3rd, 2009, 06:57 AM
kenmyfam's Avatar
kenmyfam kenmyfam is online now
The more exhaust that finds it's way under the cowling the less air there is to keep your motor running. Blown gaskets need replacing.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #4
Old September 3rd, 2009, 12:32 PM
Can I leave the engine attached and just lift the powerhead off with a chain fall? I've never done this before. Can someone point me to a thread on how to pull a powerhead? Didn't find much with the search. Is this a fairly common gasket that I can find locally (Northern Michigan)? Thanks again guys.
-Erik
  #5
Old September 3rd, 2009, 01:54 PM
iwombat's Avatar
iwombat iwombat is offline
It should be a fairly easy gasket to find. And, I can't think of any reason you couldn't do it w/ the motor on the boat. Perhaps if there's not enough clearance to remove a fastener or something, but I'm not coming up with anything. Get yourself an OEM service manual, read through powerhead removal a few times and ask questions on anything you don't understand.
  #6
Old September 3rd, 2009, 02:10 PM
You will need to get the engine high enough to scrape the old gasket off the midsection adaptor and the underside of the block.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Honda BF75 oil/gas leak? mikehoyt Honda & Tohatsu/Nissan Outboards 3 October 29th, 2007 09:48 AM
water leak 1979 115hp Sherman Johnson & Evinrude Outboards 1 August 21st, 2006 01:27 AM
1979 mercruiser 260 outdrive oil leak. Straightoutofline Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 March 22nd, 2005 03:40 AM
Fuel Leak in my 1979 Evinrude 70hp jtexas Johnson & Evinrude Outboards 5 February 21st, 2005 11:50 AM
oil leak on 1979 chrysler o/b chrisandrew69ss Force & Chrysler Outboards 0 May 28th, 2003 08:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
