foxtrotboss
- Jul 25, 2009
- 46
Ok I have been diligently working on my 1986 Force 125 rebuilding it and taking my time. Then wife decides that the Chrysler 125 powerhead advertise was the way to go. I am setting at home and she comes in the door all smug and spent only 150 dollars and says I have a good motor for the boat. Well so excitedly I go out to see this powerhead (not knowing what she bought). First thing I notice is the distributor, magnapower ignition, and this odd shaped head. She tells me the guy swears it is a exact replacement. Well yeh it will bolt to my mid leg and has the right spline crank. But..... there is no coil, the wiring harness is butchered and the belt for the distributor is trashed LOL.
I researched the best as I can and so far I have found that they didn't use a magnapower ignition on the 125. also the 125 was only listed as 81-82 with cd ignition (distributorless). Ok so what do I have. the fuel pump is on a part of the port plate but seperate with a glass sediment bowl, there is no tags on the motor and the casting numbers have not revealed anything. So tommorrow I am pulling this small double figure 8 head off. the overheat sensor is mounted in the block not the head,and measure the bore. With any kind of luck this motor will have a 3.312 bore, and I can use the pistons and rings, if they are good.
The question for now is, the conecting rods are they the same on all chrysler/Force 4 cylinder motors?
