Re: 1985 Johnson 9.9hp J10RLCOM rebuild options
Actually, I did do a compression test, and haven't taken the head off, so I don't know the condition of the cylinder walls, but I'll probably have to take it off to clean out the water passageways around the cylinders weather or not I replace pistons. Compression was around 70# for both after three compression strokes. To clean up the water passages, I'm going to see if I can find a plastic bristle wheel (a plastic version of a wire wheel).
Prior to taking it apart, it started hard, even after I got it running, and smoked a bit; normal amount or not I'm not sure. On the exahust side, one of the pistons has a fairly deep groove in it. If you look closely at the last picture in the middle port, you can sort of make it out (the size limit prevens me from uploading larger images;
here are larger versions of the images).
The pistons and rings aren't exactly cheap, but I have a friend that can hone/bore the cylinders if required. If I can get by with just a ring job for now (or not even that), I won't complain, although I'd rather do it right, even if it costs a bit more, so that in theory, I shouldn't have to touch the powerhead for anything other than spark plugs and maybe carb service for a long time (It's not likely to see salt water again for a long time, if ever).
It's very hard to tell what kind of condition the pistons are in based on your pictures. How do the cylinder walls look to you? I wish you would have taken compression readings prior to removing the head. The water passages are a mess and you will have to scrape them clean unless anyone knows of a cleaner that will remove the deposits without harming the metal. It is going to be a bit more work for you but I would get the water issues resolved and put it back together and check your compression. Then I would do a decarb. and then check the compression again. Then make a decision as to your next step. Pistons and rings and cylinder walls are expensive and why bother unless you really need to? Best of luck. Rick.
