I just purchased a 1988 Bayliner Capri w/ an outboard. Motor runs great now after a little TLC, however the entire floor in the cockpit area is rotted. Some areas are real bad such as the center near the ski locker. I am prepared for the worse as I have begun removing the seats and carpet. The area over the gas tank is real flimsy and the flooring around the passenger side seats is pretty good. I want to replace the whole floor but want to salvage the boxes that support the "lay down" seats. Need some suggestions there for starters. I am also torn between replacing the floor with 3/4" Exterior grade plywood treated with penetrating epoxy covered with Glass - not sure how much - want to end up with a glass floor not carpet. My other flooring option is Coosa Board ($$$$), however will never rot again. Looking for any suggestions. Please comment on the possiblity of the fuel tank being comprimised by the crappy floor as well.
