Re: Cajun fuse locations
The normal place for fuses would be inside your stearing console, if not there look around where your battery is located. I believe most bildge pumps use a brown wire for power so when you find your fuse block look for that. If the switch for the pump is located on your console, it's a good bet the fuses are close by. Is there any removeable panels it might be hiding behind? Irriguardless, it's gonna be between the battery and your console.
Art
