Re: 1995 115 Evinrude
Link n' Sync is the procedure to set the carb opening to the ignition timing. It is spelled out in a OEM shop manual which is really a must have if your going to work on this outboard yourself...
First of I would read all the sticky posts at the top of this forum (Top Secret Files, etc)... There is a ton of good info in there and you might be able to answer most of your questions yourself. The waking a sleeping outboard thread is very good...
After that I would do a general health check up on this engine (compression test, spark test) then plan on rebuilding the carbs with new carb kits if it has sat for awhile... There is also concerns of older fuel lines swelling and coming apart with today's "gasoline" so you might want to head off the problem and replace all the fuel lines if they have not been changed in the last couple of years with new fuel lines that are ethanol / methanol compatible...
With the info you have given it sounds like one or more of the carbs has a plugged jet IMHO... If you keep running it you chance burning up a cylinder as it's not getting enough fuel/oil if a high speed jet is plugged or partially plugged...
HTH
