  #1
Old September 2nd, 2009, 11:58 AM
carlcarew carlcarew is offline
Default 115 yamaha electric starting problem
The engine is a 2005 115 hp 4 stroke 25 inch shaft total operating hours 185. Last week after 10 or so starts and stops to reposition the boat while drift fishing, boat wouldn't crank solenoid just clicked. Had minimal tools with me at the time, batt voltage indicated 12.4 at dashboard gage. Turned off all accessories which I usually leave on while drifting VHF radio, GPS and fishfinder) and tried 10 or more times with same result. After about 10 minutes tried again and started. Drove boat directly back to boat ramp, at ramp it started fine.
Pulled boat and when home checked battery connection (slightly corroded) I cleaned and applied electrical grease and retighted both terminals. Also checked connections at solenoid (loosening inspecting and retourquing) they looked as new. Boat started 20 times in a row then once it did the solenoid click again (voltage still around 12.3) and then started 10 times again. Cleaned the ignition switch plug behind the center console, no significant corrosion, and it started 15 out of 15 times, next day again 15 out of 15 successful starts.
Some background info the week before the trip the ignition switch was left on for 4 days which totally drained the battery. Battery was recharged 3 days prior to trip and it held charge (battery showed 12.6 prior to start of trip. Also during the trip I noticed a very slight unusual engine whine during idle (this was intermittant and sounded like an alternator whine) it was not loud and did not sound like something scraping or a bearing failing. the motor is not currently making the noise when ideling in the yard on muffs.
I am reluctant to take it to a shop because I cannot demonstrate the problem, however I an uneasy as I have a single screw and usually go in the ocean.
Right now the engine starts instantly, battery holds voltage even with all the starts I mentioned and no more that a total of 10 minutes running time battery still indicates 12.4-12.6 volts. and engine starts and runs as new.
Could I have damaged any parts by leaving the key in the on position, with engine not running, for several days?
any suggestions for tests I should run? Will respond with results to any replies
Thank You
  #2
Old September 2nd, 2009, 12:05 PM
robert graham robert graham is offline
Smile Re: 115 yamaha electric starting problem
usually when my battery starts that "maybe I will/maybe I won't" stuff i just take the battery to Autozone, get it checked, and usually buy a new battery anyway. about 2 or maybe 3 years on a boat battery, since they sit around and drain/discharge a good bit, unlike a car battery that gets driven most every day. Good Luck!
  #3
Old September 3rd, 2009, 01:55 PM
Default Re: 115 yamaha electric starting problem
Robert
Thanks for the idea, I should have mentioned battery was new this April and other than going dead the time I left the key in the on position It holds a charge just fine and the motor alternator keeps at fully charged from my boat use.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starting problem on 1970 Johnson Hydro Electric Shift reverbflange Johnson & Evinrude Outboards 2 July 28th, 2009 09:20 AM
Yamaha 9.9 F9.9SJ Starting Problem George Van Yamaha & Suzuki Outboards 2 July 7th, 2009 03:36 PM
20 hp merc electric starting problem seadog59 Mercury & Mariner Outboards 3 May 17th, 2009 10:43 AM
Yamaha 115 starting problem mygrandson123 Yamaha & Suzuki Outboards 8 October 3rd, 2006 11:28 AM
40 hp yamaha electric problem bradleyrh@peoplepc Yamaha & Suzuki Outboards 3 July 30th, 2002 05:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
