  #1
Old September 2nd, 2009, 01:55 AM
Roadrage Roadrage is offline
Default My SmartTabs results on my 192
Finally tried out the sx smarttabs that I had installed a few weeks ago.
I am very pleased with results .
This is on an 07 192 with 190hp merc with 19p hi 5 prop
I didnt have a gps so speeds are via speedo
Minimum plane is now 20mph @3000rpms
Before tabs min plane 23-25 @3200rpms
So 200 rpms lower & stays on plane solid @3000rpm.
exactly what I was after .
The boat leaps on plane from a standing start now ,I thought it was pretty good before tabs , but now , I AM IMPRESSED with my lil v6 .
I had started with the tabs at the #4 setting but top speed was down to 42mph (speedo) had it up to 46mph(speedo)earlier in the year.
So I backed tabs to the last setting.
Top speed up to 44mph ... good enough .
The boat behaves much better now with the tabs .
I can now trim up & boat doesnt porpose at any speed ..( it was bad before )
The boat also handles chop from other boats or rough water way better .
Might be the fact that I can now trim up a bit more .
But I swear that its a much smoother riding boat in rough water than it was before .
Added plus for me is trolling speed is even slower than it was before tabs .
Must be the extra drag in the lowered position.
So slap a set of smarttabs on your 192s you wont be sorry .
btw I used the 60lbs shocks with sx tabs ( the plastic ones )
Jim
  #2
Old September 2nd, 2009, 09:16 AM
mvn's Avatar
mvn mvn is offline
Default Re: My SmartTabs results on my 192
Jim,
Great to hear! Exactly the same results I have been able to get. You may also notice reduced low speed wander typical of I/O's.
The Hi 5 must look awesome! I've yet to see one up here.
Enjoy the rest of the summer.
Mark
__________________
2005 Rinker 192, 4.3L Volvo SX, SX Smart Tabs, Precision Props 4-blade SS prop
2007 GMC 2500HD Duramax/Allison @450 hp haulin' it all
  #3
Old September 2nd, 2009, 10:20 AM
For sure the low speed wander is a lot less.
Its kinda like a new boat, to me now.
I put over 60+ hrs on her this year alone.
Too bad summer weather just came now to the province.
Hi 5 looks blingy but I would like to play with a different props.
WOT runs were @ 4900rpm & it didnt feel like it was hitting rev limiter .
My WOT runs before tabs I could hit the rev limiter .
But different water conditions might be the cause
Should use a gps to verify speeds .
I think a 20p hi 5 would be perfect for me , but they dont make one .
Got a lil nick on the hi5 now & if I get it fixed i might see about getting
the pitch tweeked a bit.
Or better yet forget to winterize the engine this winter & get a 383 MPI
for my lil Rinker.
Jim
  #4
Old September 3rd, 2009, 12:03 PM
JBeach327 JBeach327 is offline
Did you mount in same location as MVN?
  #5
Old September 3rd, 2009, 11:20 PM
yep, same as MVN did
Check out his pics
thats the only place you can stick them .
Kinda mad that I didnt install them last year .
Just go with the 60lbs actuaters as I believe
Mvn tried them all out .
I am a lil under propped so my top speed is a little lower &
my revs are hi , but it works for me .
The tabs just made my boat better ...
Jim
  #6
Old September 4th, 2009, 10:32 AM
mvn's Avatar
mvn mvn is offline
In combination with the tabs, I tried a number of props. I found that you have to go to a cupped stainless prop to really take advantage of everything the SmartTabs have to offer.
All props were 4-blade Precision Props stainless steel at 14 1/4 diameter. I tried 18", 20" and 22" props. I made a little spreadsheet that calculates the theoretical boat speed taking prop efficiency, drive ratio, prop pitch and engine speed into account. The magenta line is pitch versus max WOT rpm and the blue line is pitch versus max boat speed.
The theoretical results were verified by GPS.
The 18" pitch made the boat feel like a freight train but the top end was way down. the 22" gave it great top end but gave poor performance when loaded. I'm running the 20" right now with good overall performance.
Mark
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Ya-Hoo! My new SX SmartTabs arrived! KaGee Boat Topics and Questions (not engine topics) 6 May 29th, 2007 03:42 PM
The new SX series SmartTabs KaGee Boat Topics and Questions (not engine topics) 20 March 20th, 2007 02:02 PM
Where to mount SmartTabs? Paul R Boat Topics and Questions (not engine topics) 3 June 28th, 2006 08:57 AM
Another SmartTabs testimonial kenimpzoom Boat Topics and Questions (not engine topics) 4 May 2nd, 2006 10:33 AM
SmartTabs, again wgander Boat Topics and Questions (not engine topics) 21 September 20th, 2004 03:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
