  #1
Old September 1st, 2009, 08:02 PM
marinemike43 marinemike43 is offline
Default Mercury Timing belt change and year
Can anyone give me a rough breakdown on how to change the timing belt?
Mercury 115 Direct Charge
And not sure the year of this engine Serial # 6560150
Number stamped on boat is HSX02610M76F
Thanks Mike
  #2
Old September 1st, 2009, 08:38 PM
daveswaves's Avatar
daveswaves daveswaves is offline
Default Re: Mercury Timing belt change and year
And not sure the year of this engine Serial # 6560150 (Thinking its a 84)
Thanks Mike
If you are talking about the belt that drives the distributor then the newest it can be is a 1978. Is the belt currently broken? Do you have a new one? If not then leave it be.
__________________
Mercury inlines....nothing else stacks up
The answer to "do i need to change my water pump impeller" is YES
  #3
Old September 1st, 2009, 08:41 PM
The Timing belt is broke.
Bought a new one to replace
  #4
Old September 1st, 2009, 08:51 PM
daveswaves's Avatar
Well in that case by all means replace it. When you remove the top plate of the distributor pulley (remove the bolt in the center) you will see a dot on the gear. This dot lines up with dots on the flywheel, or just to one side of them in some cases. You will have to remove the flywheel in order to put the belt over the crank pulley, then re install the flywheel so that you can match up the marks. Most manuals have a decent picture showing this, even the aftermarket ones like Seloc. I strongly suggest that you purchase one, a picture is definitely worth 1000 words for this job. Its not a difficult job.
__________________
  #5
Old September 1st, 2009, 08:54 PM
Thank you for the information
  #6
Old September 3rd, 2009, 02:56 PM
Chris1956 Chris1956 is offline
Mike, Set the flywheel to TDC. Remove the eight 5/16-24 bolts around the flywheel nut. I still think you will need to remove the inner flywheel, to get the timing belt to go onto the pully, due to the belt guard cast into the top of the block.
  #7
Old September 3rd, 2009, 09:54 PM
daveswaves's Avatar
Quote:
I agree Chris, the complete flywheel has to come off.
__________________
  #8
Old September 3rd, 2009, 11:38 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Chances are the reason it broke was something in the distributor that had momentarily locked up. Like bearings or something.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 4 stroke timing belt change? Redneck Yamaha & Suzuki Outboards 7 December 2nd, 2007 09:38 AM
when to change timing belt on 500 50hp dave37 Mercury & Mariner Outboards 4 October 25th, 2007 08:18 PM
timing belt change out jwilkey84 Mercury & Mariner Outboards 2 July 12th, 2007 09:07 PM
850 mercury need help with belt timing Egriff Mercury & Mariner Outboards 5 May 15th, 2006 08:38 PM
Volvo - Timing belt and bearing change BrianG Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 1st, 2002 08:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
