jpinheiro33
- Sep 1, 2008
- 21
Hey, we bought a boat roughly two years ago and since then have had a pinging over 3200 rpm's. obvious and probable cause is timing, i understand that. what i dont understand, and my main problem being and have researched and got no where is why isnt the vacuum hooked up on my distributor? its the type of dstrburt that has the coild built into the top (fyi). My initial thought to fix "the ping" is to check the timing correctly (i have all the proper tools to do so) but i cant get passed this whole vacuum issue, the peice to hook the vacuum is on the distributor but is just not hooked up. The engien has power, we have been using it for two years now and the pinging is starting at 3000 rpms now... so we are looking into it. The engine was supposedly replaced about 4 years back, no way to verify exactly what the engine is but the block casting number reads that of a 95-00 zz4 chevy 5.7l 350. ANY help would be greatly appreciated as the tuna are coming soon and we are looking to get out there reliably! Thanks for your time!!!!!!!
