  #1
Old September 1st, 2009, 01:35 PM
NWdoug NWdoug is offline
Default Mercury 9.8 impeller issue
I have an early 1980's 9.8hp model 110 that seems to be eating water pump impellers. The last one only lasted 3 trips to the river. Does anyone know what would cause this to happen?
  #2
Old September 1st, 2009, 02:03 PM
emckelvy emckelvy is offline
Default Re: Mercury 9.8 impeller issue
What does the impeller look like, is it burnt up or ground up? Post a small pic if you can.
You might be getting a lot of silt/sand from the river. What do the pump plate and 'cup' insert look like and have you replaced them yet?
Is the motor mounted on the back of a large boat or directly on the transom of a small runabout? If a large boat, it may not be far enough in the water and/or sucking air from wave action.
How do the plastic pump parts look? If the motor had been run dry in the past, plastic may have melted and run down into the impeller area. This melted plastic will rub on the impeller and wear it out or tear it up in short order.
Does the impeller fit snugly on the driveshaft? There are (2) different diameters of driveshaft on certain models, and impellers to fit same. If you have the large-I.D. impeller on a small-I.D. driveshaft, it'll be real sloppy and that could lead to problems.
One last thought, if the suction side of the pump has a clog somewhere, that'll restrict water flow to the pump. You should notice a lack of flow out the telltale if this is happening.
HTH.........ed
  #3
Old September 1st, 2009, 02:21 PM
The motor is on the back of a 14' gregor. the impeller was completly shredded into small pieces. The pump plate and the the cup look to be in good shape.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Possible impeller issue? backwater dawg Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 May 31st, 2009 05:56 PM
56 johnson seahorse 7.5 ad-10 m impeller issue rustyh Johnson & Evinrude Outboards 4 April 20th, 2009 09:51 PM
Impeller issue? What? (video inside) Big Sarge Mercury & Mariner Outboards 4 March 28th, 2009 12:52 AM
94 evinrude 25 hp. impeller issue marley522 Johnson & Evinrude Outboards 1 June 10th, 2007 10:35 PM
Johnson 6hp impeller key issue wolfebrother Johnson & Evinrude Outboards 2 August 7th, 2006 06:18 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
