PowerAddict
- Aug 8, 2007
- 418
I have a leak around the filler ring. is there any way to fix this?
Sounds like your leak is not on a flat open area where a patch or sheet patch would work. I've had good luck with a tube of vinyl repair from the local ace hardware store called VLP clear Liquid Vinyl Repair. There are many other brands too. I've heard a good one that Sevylor themselves make called Air Leak but I can't find it locally.
My problem is not the gluing but finding the damn leak! Sure you can use a soapy wet towel or spray bottle but it is hard to listen and look. Right now I have a huge 3 person sit inside tow tube - like 3 separate compartments, and an inflatable slide that is attached to a round inflatable platform.
It is SO hard to find - any ideas?
thanks, -matt
