September 1st, 2009, 10:29 AM
1999 115 HP Evinrude Ficht booging down at 2500 RPMs
Changed the fuel filter and primer bulb. The bulb does not get firm after pumping it. Seems as though the motor is not getting enough fuel. Please help....
September 1st, 2009, 12:55 PM
Re: 1999 115 HP Evinrude Ficht booging down at 2500 RPMs
What are the diagnostic sw results from interrogating the EMM?
__________________
Jim
September 1st, 2009, 02:09 PM
Haven't got a diagnostic report yet, I was seeing what I could do before going that route.
September 1st, 2009, 02:24 PM
Had the same problem with my 115. Dumped old gas and put in fresh, and it ran better.
Then removed carbs and found ball valve on bottom of throttle body assembly was plugged up with grease like sludge. Cleaned it out, and she runs perfectly again.
September 1st, 2009, 02:38 PM
This motor is a Ficht with no carbs. It's a DI motor.
__________________
Jim
September 1st, 2009, 04:04 PM
Sounds like a bad/weak lift pump, if it original its due to be replaced anyway..
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
September 1st, 2009, 04:19 PM
Lift pump is a dealer install item only. The fuel system components are expensive ... you want to get a BRP dealer to diagnose and replace only what's necessary.
__________________
Jim
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
Thread
Thread Starter
Forum
Replies
Last Post
2500 Rpms At Wot
mikbry
Mercury & Mariner Outboards
4
August 7th, 2009 03:53 AM
2500 rpms at WOT??
88seville100
June 23rd, 2009 07:13 PM
Wa,wa,wa,wa,wa, 2500 Rpms
AQUASPORT17.5
Johnson & Evinrude Outboards
9
July 31st, 2007 05:50 PM
OMC 305 GM STILL will not go over 2500 rpms
kicks2
Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives
September 16th, 2003 10:23 AM
OMC 5L won't go over 2500 rpms
kicks2
August 31st, 2003 08:33 PM
