First you have to get the engine end of the cable to 7 9/16 in. Then you place the bellcrank in the proper position (I use a staight edge as I don't have an alignment plate) and screw in the retainer nut until it just contacts the cable guide. Put on the locknut to specs making sure not to move anything out of adjustment and you should be set.
