Timing: Vaccum Advance on new electronic ignition
Medic0893
I have a 1973 OMC - Chevy 4.1L inline 6. I am replacing the engine and in the process I installed a new electronic ignition module (replacing the points) in the distributor. I noticed it has a vaccum advance plate on the new ignition, but the boat doesn't have a vaccum advance setup on the distributor.
What should I do with the vaccum advance adjustment? All the way to the left, all the way to the right or somewhere in between? Do I need to secure it so the timing doesn't change?
Help is greatly appreciated...
Bifflefan
Re: Timing: Vaccum Advance on new electronic ignition
It needs to be secured so it doesnt move.
Altho im having a hard time picturing it in my head. if you can post a couple pics and the makes and model of all the parts.
Don S
Sounds to me like you have the wrong kit. You have one for automotive, not marine
What is this "Module" you have. Manufacturer and part numbers, etc. may help.
Medic0893
Thankx guys... I'm at work so I don't have access to the specifics/pictures. I will get them and post them
