was out last weekend an hit the prop a bit on the bottom. (wind pushed too close to shore) Now its really not bad, but you can see a slight bend in one blade and roughed up the edges on all three. Would it cause much damage to use as-is untill I can get it repaired? I know if it's out of balance I heard it can ruin your outdrive seals and bearings? It is on a '04 mercruiser alpha I.
Also what does it run (approximately) to repair such damage? thanks ahead of time.
