Quote:
Originally Posted by jfmil355
I took my boat out for the first time last weekend and it ran great. When I put the drive in reverse it sounded like the gears were not engaging fully. It worked fine hours earlier. What could be the cause of this? Could low oil/dirty oil in my lower unit be causing this? Please help! What should I check?
Yes, it certainly can be low/dirty/wrong oil. And/or water in the oil. It can also be low voltage to the shift solenoids (bad shift switch is all too common). It can also be worn out oil pump in the lower unit, however that is unlikely since it was working earlier.....unless that is combined with very slow idle.
