Re: Alpha one sterndrive removal question
well if you buy a used one, then plug n play, you are trusting that everything in the new one is okay
if the case is okay, i.e. not damaged like cracked or gouged on the inside, you could get the new bearing set and gear set, but you're gonna need the special tools to shim the new gears and a rolling tourqe wrench to set up the bearing set
its up to you, price it out both ways
