  #1
Old August 31st, 2009, 04:37 PM
CharlieZulu CharlieZulu is offline
Default Newbie question on buying used boats
Hello everyone:
I have read as much as I can on the FAQ about what to look for, etc but have a few specific questions.
I am looking at a 1980 Crestliner bowrider, 16' with a 1975 Merc 650. It will be my first boat and plan to use it for casual cruising in fresh water. I know it's a bit of a dinosaur, but I hope to get it at a good price.
The boat has been in storage for the last 4 years, was purchased by the current owner who has run it 6-7 times this summer. He has had the motor tuned and says it runs great. I know that doesn't mean much unless I can get to the mechanic who did the tuneup. I am going to go and see it ( and get it in the water) this weekend.
Question: any pros/cons on old Crestliner bowriders? What to look for?
Also, I know next to nothing about the pros/cons on short shaft vs long shaft. What is supposed to go with this boat, long shaft?
Pic:
  #2
Old September 1st, 2009, 10:24 AM
ezmobee's Avatar
ezmobee ezmobee is offline
Send a message via MSN to ezmobee
Default Re: Newbie question on buying used boats
That boat looks absolutely cherry. Your main concern on an older fiberglass boat is rot in the transom, deck, or stringers. Replacing any of these is a major job and the materials are kinda pricey. Check carefully for any soft spots in the floor and check out the transom as best you can. It would be fantastic if you could get an on the water test drive. If everything checks out it looks like a great first boat.
Tri-hulls can have a pretty rough ride in the chop but are very stable. They are also great fishing rigs.
__________________
1976 18' Starcraft SuperSport 90HP Evinrude
Restoration thread http://forums.iboats.com/showthread.php?t=357767
1966 16' Starcraft Jupiter 85HP Johnson
Restoration thread http://forums.iboats.com/showthread.php?t=338633 sold
  #3
Old September 1st, 2009, 11:49 AM
Floatsum Floatsum is offline
From the pix,, it looks great.
Get under it and check the hull closely. You'd see anything that's obviously afoul.
Take it for a ride with you at the helm. Make sure all controls work freely as they should. If the motor starts right up, runs good, no issues, you're lucky.
Look under things for scarfed wireing, mold, greasy bilge, etc.
If your toes curl with anticipation,,, buy it.
Remember, the motor may seem perfect at the time, but, some things let go unexpectedly and without warning. Things like electronics for instance.
Near season's end (at least here). Keep that in mind. run the crap out of it for the rest of the year and have it winterized and meticulosly tuned and looked over for next year.
You should be good.
Enjoy.
PS; I don't see any prior registration on it. Make certain there is not an issue with paperwork.
If it looks so darn good from a recent paint job,,, I'd get a red flag on that and really start picking things apart.
Personally, I wouldn't even consider a painted glass or aluminum boat unless there was something truely outstanding about it.
I know, some will recondition a boat flawlessly,,,, but many more paint to hide.
  #4
Old September 1st, 2009, 12:20 PM
Thanks guys for the great advice.
The boat looks nice because the current owner has just stripped the paint and sanded all the outside of the boat and repainted yellow and orange marine paint 5 coats each. He hasn't done the Reg numbers and graphics/logos, etc yet.
It would help if I understood something about the construction of these boats -- I can easily check the transom I guess, since it's right there, but how/where do I check the "stringers"?
Were these boats completely fiberglass or is there wood or a wood frame somewhere I need to get at?
When it comes to the deck -- I presume this is what I stand on -- would this typically have been fiberglass also?
More pics:
  #5
Old September 1st, 2009, 12:36 PM
ezmobee's Avatar
Even the trailer looks to be in great shape.
Stringers are typically strips of wood (usually plywood, at least partially encased in fiberglass) that run the length of the boat). They stiffen the hull and provider support for the floor.
It would be tough to actually check the stringers. Boats typically rot from the bottom up so by the time a soft spot shows up on the floor, the entire stringers are usually gone.
The transom is layers of plywood added to the stern to support the weight and force of the motor.
__________________
  #6
Old September 1st, 2009, 01:02 PM
Thanks again -- the owner has redone the trailer as well, new paint, new submersible wiring and lights.
  #7
Old September 1st, 2009, 01:24 PM
KurtG's Avatar
KurtG KurtG is offline
The only thing that concerns me is that it looks like the boat is stored bow down. It looks well kept otherwise, I'd still check the floor carefully.
  #8
Old September 1st, 2009, 01:55 PM
Quote:
Sorry -- what do you mean "stored bow down", please?
  #9
Old September 1st, 2009, 02:03 PM
BF BF is offline
he means that it should be stored with the trailer tongue elevated (with with a tongue jack or putting something under it), and the plug in the transom pulled.... that way, any water that gets in (rain etc.) drains out instead of sitting under the deck.
BTW, those boats are constructed with wood (probably plywood) in the transom, sandwiched between the outer and inner skins (fiberglass). There are also wooden stringers (running from the transom forward)... basically boards on edge... and then a deck (probably plywood) that is fiberglassed over.
Water sitting under the deck will cause it to rot and get soft, and with the stringer rotting close behind.
BTW, I'm not a huge fans of trihulls... they rattle your teeth in chop and tend to be heavy.... That looks like a lot of boat for a 65 hp motor to push. It might be ok for cruising, but a bit of a dog for watersports.
Anyway, that's my $.02
good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Newbie buying a new pontoon hettman Pontoons 5 July 16th, 2009 06:21 PM
Boating newbie looking at buying a '90 Bayliner Capri - help with buying advice! Rushabh Bayliner Boats 3 May 10th, 2009 09:00 PM
Newbie buying a Force punkrguy Force & Chrysler Outboards 13 January 12th, 2009 10:53 AM
Newbie buying a (little) jet boat cincy_cosmo Boat Topics and Questions (not engine topics) 6 August 9th, 2007 11:23 AM
Cooling question(Newbie to Boats) bigtom Johnson & Evinrude Outboards 5 June 19th, 2007 09:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
