Re: New Motor to Me
Well, I knew the previous owner - so, I'm pretty sure there aren't any immediate issues to keep me from running it a little, so - I just checked the lower unit oil - and have run it a few times. It actually seems to go pretty good - it is on a small 12 foot row boat, but gets up on plane and I would guess goes about 15mph with me 280 lbs in the back, and 2 cinder blocks in the bow to balance the load. So, this is how it seems to perform -
Jumps right up on plane and then seems to peak speed at about 8mph and seems like that is all the motor has, then I shift my weight forward about 2 feet to get the bow down(I call this manual trim) and it gets up to an estimated 12 mph - then when I shift my weight back again - there is more speed and RPM left in the motor and it gets up to around 15mph - I'm zipping right along up on plane - so, I'm not sure the performance benefit I'll get would justify the work of raising the motor a couple inches? I'm pretty happy with it, but if I could get even more out of the motor I'd consider a solution to raise the motor.
