Re: 1970 115 evinrude water hole question
If you are not handy, you may be able to pickup a used outer exhaust cover from a 78 (and newer) flatback engine. It is pre-drilled for the telltale hose barb. Check the water routings vs your current outer cover, as the gaskets are different. It may work just fine. You will need to drill a hole in the lower cowl and pickup a nozzle.
